Solved
Meory speed
i have amd T1100 processor on a new 990 biostar b using 1600 memory could i speed it up by going to 1866 low 8-8-8 memory would i see the differnce that much using 16 gb 'tom f
3 answers Last reply Best Answer
More about meory speed
  1. Best answer selected by tom f.
  2. Best answer
    hi
    no noticeable difference.
    I went from 1066 to 1600 and didn't see any difference with gaming.
    I think the only way you may see a bit of difference anyway is when you overclock (over 1600)
    Depends on your brand and quality of memory. If its cheap value RAM then you wont be able to, and honestly unless you do things that require a lot of memory bandwidth you wont notice the difference.
Corsair Processors Memory
