Solved
[New Build] $975(Australian Dollars) - Need Help
  • New Build
  • New Build
  • Systems
Last response: in Systems
September 4, 2011 9:15:02 AM
Hey looking to buy a new PC and I have no clue on what to get, my friend suggested i come here.
I pretty much need everything except Mouse and Keyboard.
Budget Limit: $975.00(AUD)
Prefered site: http://www.pccasegear.com
If possible can i get everything from here.
Prefer an Intel machine, something good for; Photoshop, 3d rendering, gaming, video and surfing the web.
Thanks in advance
More about : build 975 australian dollars
September 4, 2011 11:45:14 AM
ervinelim said:
Hey bro, I think you should follow the template so that it will easier for you and the builder ^_^
http://www.tomshardware.com/forum/261222-31-build-advic...
Thanks.
Approximate Purchase Date: ASAP.
Budget Range: $975(AUD)
System Usage from Most to Least Important: Photoshop, 3D rendering, watching movies, gaming and surfing the internet.
Parts Not Required: keyboard, mouse, speakers and OS
Preferred Website(s) for Parts: http://www.pccasegear.com
Country of Origin: Australia
Parts Preferences: Intel CPU & 24" Monitor
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Additional Comments: Quietish machine plz
m
l
September 4, 2011 11:47:15 AM
When you say gaming, can you please tell us what games will you play?
m
l
September 4, 2011 11:48:47 AM
CoolerMaster Centurion 5 II With 500W PSU (Black)
In stock $105.00 $105.00
Intel Core i5 2500K
In stock $219.00 $219.00
CoolerMaster Hyper 212+ CPU Cooler
In stock $33.00 $33.00
MSI GeForce GTX 560 Ti Hawk 1GB
In stock $299.00 $299.00
Kingston ValueRAM KVR1333D3N9K2/8G 8GB (2x4GB) DDR3
In stock $59.00 $59.00
Seagate Barracuda 1TB ST31000524AS
ASRock Z68 Extreme3 Gen3 Motherboard
In stock $145.00 $145.00
Sub-Total: $919.00
http://www.pccasegear.com/
m
l
September 4, 2011 11:49:16 AM
Most likely BF3 which i dont mind playing on lower GFX and Minecraft
m
l
September 4, 2011 11:51:44 AM
Intel Core i5 2500K
Sub-Total: $919.00
No room for a Monitor in that budget?
m
l
September 4, 2011 11:52:17 AM
Cooler Master PSU? Aren't they the ones to avoid at all cost?
m
l
September 4, 2011 11:54:43 AM
You can change the GPU to an AMD 6850 which is cheaper and get a cheaper casing and psu. I don't think he needs the cooler since he won't be overclocking.
m
l
Best solution
September 4, 2011 12:00:37 PM
How bout this:
Intel i5 2310 - $185.00
ASRock Z68 Pro3 Motherboard B3 - $129.00
HIS Radeon HD6870 IceQ X 1GB - $199.00
G.Skill Ripjaws F3-12800CL8D-4GBRM (2x2GB) DDR3 - $45.00
Samsung SpinPoint F3 1TB HD103SJ - $69.00
Lite-On IHAS324 24x DVDRW - $29.00
Antec Three Hundred Case - $59.00
CoolerMaster eXtreme Power Plus 650W - $85.00
ASUS VE228H 21.5in Widescreen LED Monitor - $165.00
Total = $965.00
although i would probably spend the little extra and get the Intel Core i5 2500K - $219.00
September 4, 2011 12:05:58 PM
hahaha
m
l
September 4, 2011 12:07:51 PM
or if you want 24inch:
Acer V243HLBD 24in Widescreen Monitor - $169.00
m
l
September 4, 2011 12:57:45 PM
If you look at the new build section 2 posts above this you will see that you have not evan built a pc before. you have no cule what your evan doing, why are you putting together builds for people.?????
eldudus said:
How bout this:
Total = $965.00
m
l
September 4, 2011 1:01:39 PM
Dude, from looking at this link
http://www.tomshardware.com/forum/320142-31-build-revie...
You can't even read.
m
l
September 4, 2011 1:05:28 PM
haha i cant read lol
m
l
September 4, 2011 1:15:17 PM
I guess because someone typed a review it must be true, Get your facts in order.
m
l
September 4, 2011 1:23:21 PM
Granted, multi monitor resolutions would have likely seen the 3GB Lightning XE pulling off some impressive wins but we weren’t given a pair to play around with. Plus, spending $1200 or more on two of these cards is more than all but a few upper-crust enthusiasts are willing to spend
If you could read you would see that the reviewer did not evan have the cards. So ill say again get your facts straight.
m
l
September 4, 2011 1:25:40 PM
We know.
m
l
September 4, 2011 1:31:32 PM
Why don't you take your ball and go home its ok, we all know your an in-the-closet-homosexual.
ervinelim said:
We know.
m
l
September 4, 2011 2:18:53 PM
Best answer selected by JamJam411.
m
l
