How to bypass power on button on pc
  • Power Supplies
  • Power
  • Computers
  • Components
Last response: in Components
December 4, 2011 12:38:43 PM
My computer will not power on when I press the power button. The green light to the power button flashes when plugged in though. Is there a way to bypass the power button and turn on the computer? M2N68-LA mother board in an HP
More about : bypass power button
a b ) Power supply
December 4, 2011 12:52:58 PM
You can disconnect the power switch lead to the motherboard and touch the pins with a screwdriver, but that's not a long term solution. Your problem is either with the power supply or the motherboard, unless you broke a wire on the power switch lead.
m
l
December 4, 2011 3:32:40 PM
thanks I appreciate the quick reply. It's the power supply. I'm going to replace it
m
l
