I am in the middle of building with the list below. In connecting the Front Panel Audio on the Antec nine Hundred Two case it has a wire that has two connectors in series that say HD Audio and AC97. The case instructions say to make sure the pins match to the motherboard or or may mess it up. Below are the pin lists. The first 10 are for the HD Audio. I listed the motherboard pin definitions first followed by the connector coming from the front panel with a / in between. The ten below those are for the AC(& and are listed the same way.
HD AUDIO front panel
Motherboard PINS / Front Panel Wiring Connector
1 MIC2_L / MIC2 L
2 GND / AGND
3 MIC2_R / MIC2 R
4 -ACZ_DET / AVCC
5 LINES2_R / FRO-R
6 GND / MIC2_JD
7 FAUDIO_JD / F_10_SEN
8 No Pin / Key (no pin)
9 LINE2_L / FRO-L
10 GND / LINE2_JD
AC97 Front Panel
1 MIC / MIC InL
2 GND / GND
3 MIC Power / MIC Power
4 NC / NC
5 Line Out R / Line Out R
6 NC / Line Out R
7 NC / NC
9 Line Out L / Line Out L
10 NC / Line Out L
Do either of these match up? If not, how do I fix it? The motherboard seems to only have one audio plug in place.Do I pick one or the other and leave the othr hanging?
Below is a link to the case maual
http://www.antec.com/pdf/manuals/900II_EN_manual.pdf
Below is the Motherboard Manual
[url=http://www.antec.com/pdf/manuals/900II_EN_manual.pdf]Gigabyte Z68 motherboard Manual[/url]
Update Antec Nine Hundred Two V3 Black Steel ATX Mid Tower Gaming Case Antec Nine Hundred Two V3 Black Steel ATX Mid Tower Gaming CaseModel #:Nine Hundred Two V3Item #:N82E16811129097Return Policy:Standard Return PolicyIn StockMail in Rebate
Note (Add)
$119.99 $239.98
Update GIGABYTE GA-Z68MX-UD2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard GIGABYTE GA-Z68MX-UD2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel MotherboardModel #:GA-Z68MX-UD2H-B3Item #:N82E16813128503Return Policy:Standard Return PolicyIn Stock
Note (Add)
$159.99 -$10.00 Instant $149.99
Update Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE ...Model #:HCG-750Item #:N82E16817371049Return Policy:Standard Return PolicyIn Stock
Note (Add)
$129.99 -$30.00 Instant $99.99
Update Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600KModel #:BX80623I72600KItem #:N82E16819115070Return Policy:CPU Replacement Only Return PolicyIn Stock
Note (Add)
$314.99 $314.99
Update CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9B CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9BModel #:CMZ16GX3M4A1600C9BItem #:N82E16820145347Return Policy:Memory Standard Return PolicyIn Stock
Note (Add)
$114.99 -$10.00 Instant $104.99
Update Intel 311 Series Larsen Creek 20GB 2.5" SATA II SLC Enterprise Solid State Disk SSDSA2VP020G201 Intel 311 Series Larsen Creek 20GB 2.5" SATA II SLC Enterprise Solid State Disk SSDSA2VP020G201Model #:SSDSA2VP020G201Item #:N82E16820167062Return Policy:Limited Replacement Only Return PolicyIn Stock
Note (Add)
$129.49 -$15.00 Instant $114.49
Update Rosewill RCR-IC002 74-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plate Rosewill RCR-IC002 74-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plateModel #:RCR-IC002Item #:N82E16820223109Return Policy:Standard Return PolicyIn Stock
Note (Add)
$16.99 $16.99
Update Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare DriveModel #:WD7502AAEXItem #:N82E16822136794Return Policy:Standard Return PolicyIn Stock
Note (Add)
$64.99 -$6.00 Instant $58.99
Update ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEMModel #RW-24B1ST/BLK/B/ASItem #:N82E16827135204Return Policy:Standard Return PolicyIn Stock
Note (Add)
$20.99 $20.99
1 MIC2_L / MIC2 L
2 GND / AGND
3 MIC2_R / MIC2 R
4 -ACZ_DET / AVCC
5 LINES2_R / FRO-R
6 GND / MIC2_JD
9 LINE2_L / FRO-L
10 GND / LINE2_JD
AC97 Front Panel
1 MIC / MIC InL
2 GND / GND
4 NC / NC
6 NC / Line Out R
7 NC / NC
10 NC / Line Out L
Note (Add)
$119.99 $239.98
Note (Add)
Note (Add)
Note (Add)
$314.99 $314.99
Note (Add)
Note (Add)
Note (Add)
$16.99 $16.99
Note (Add)
Note (Add)
$20.99 $20.99
