I am looking at building an HTPC, maybe in this case:
http://www.antec.com/Believe_it/product.php?id=MjA5MyY2
It will be for exactly what you expect in an HTPC... watching video, streaming, downloading etc. No TV tuner or recording. So my needs are quite modest. The budget is not that much of a concern - what is important is that it is cool and quiet.
With that in mind, should I go with an i3 or a Llano? If Llano, what is the best one for this purpose?
I am hoping to use ubuntu so that I don't need to pay for Windows. Will AMD be a problem for that?
Also, that case comes with two variants - one with a 65W adapter outside the enclosure, and one with a 150W power supply inside. Would the 65W one be enough for my needs?
Thanks in advance for your help.
