Will these parts work well together? opinions welcome!
• Case-IN WIN Dragon Rider Black 1.0 - 0.8mm SECC Steel ATX Full Tower Computer Case
o http://www.newegg.com/Product/Product.aspx?Item=N82E16811108376 141.99
• Processor- Intel Core i5-2500 Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I5250
o http://www.newegg.com/Product/Product.aspx?Item=N82E16819115073 209.99
• Hard drive- SAMSUNG EcoGreen F4 HD204UI 2TB 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
o http://www.newegg.com/Product/Product.aspx?Item=N82E16822152245 79.99
• RAM- CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9B
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145347 104.99
Motherboard- ASUS P8P67 DELUXE (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131701 224.99
Wireless adapter- Linksys WMP600N Wireless Adapter with Dual-Band IEEE 802.11a/b/g, IEEE 802.11n Draft 2.0 PCI WEP, WPA & WPA2 Personal, WPA & WPA2 Enterprise
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124342 49.99
Graphics Card- XFX HD-695X-CDDC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150548 289.99
Power supply- CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 84.99
CD Reader- SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B – OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031 16.99
Keyobard/Mouse- Logitech MK520 USB RF Wireless Ergonomic Desktop
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126192 49.99
You can just forward any comments to my email: Matsmith808@gmail.com
Thanks so much
4 answers Last reply
More about will parts work together opinions welcome
  1. Hi there, welcome to the forums.
    While they all WORK, it's not a good build (for GAMING) not sure what you need it for, but if you could give more information (or just fill in the form at the top of the sticky) about the intended use of the machine, it would help alot.
    http://www.tomshardware.com/forum/261222-31-build-advice
    Cheers!
  2. Fair point haha, sorry yes I am looking to design a gaming computer.. This is the first time I've actually attempted to build a desktop from scratch.. So it'll take me a while to catch onto things haha.. Thanks!
  3. If the graphics card is the problem, how bout this one instead?http://www.newegg.com/Product/Product.aspx?Item=N82E16814121467
    Approximate Purchase Date: (e.g.: this week (the closer the better))
    Budget Range: somewhere around 1,500$
    System Usage from Most to Least Important: gaming! school projects and other misc.
    Parts Not Required: I plan on using my flat screen tv as my computer monitor, everything else i need (casing, power supply, wireless keyboard/mouse)
    Preferred Website(s) for Parts: I have mainly used Newegg.com for my searches
    Country of Origin: I'm from the U.S.A.
    Parts Preferences: by brand or type: whatever works best for gaming
    Overclocking: why not?
    SLI or Crossfire: no
    Monitor Resolution: (1080i/p since i'm utilizing my tv monitor
    Additional Comments: none
  4. Motherboard: ASRock Extreme 3 or 4 GEN3 (P67 or Z68)
    CPU: i5-2500k
    GPU: 560Ti/6950 or 570/6970
    PSU: 500w/650w for single card or 750w/850 for SLI/Crossfire
    RAM: 8GB (2x4GB) 1600MHz 1.5v CL9
    HDD: Samsung SpinPoint F3 1TB (get 2 and RAID 0 if you want more space)
    Optical Drive: DVD-RW
    Case: Of your choice :) Almost any mid/full Tower ATX
New Build Systems
