Hi im planing on building a new system in the next few weeks. It will be my second build, the first being 5 years ago so I want to run it by everyone first because I'm sure there's probably some better component options. Thanks for the help!
Approximate Purchase Date: within the next 3-4 weeks
Budget Range: 900-1000 but preferably as cheap as possible
System Usage from Most to Least Important: games, movies, CAD, Photo editing, internet
Parts Not Required: keyboard, mouse
Preferred Website(s) for Parts: newegg, but i dont mind buying elsewhere for deals
Country of Origin: USA
Parts Preferences: Intel CPU
Overclocking: Most likely
Crossfire: may purchase another graphics card next year
Monitor Resolution: 1920x1080
Additional Comments:
1. Will the motherboard i selected be compatible with ivy bridge and crossfire should i choose to upgrade in the future?
2. Will the power supply be able to run 2 6950 cards?
3. Do I need additional case fans?
4. Do I need a cpu cooler?
CPU - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
GPU -MSI R6950 Twin Frozr II Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.731454
RAM - [strike]G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model F3-8500CL7D-8GBRL[/strike]
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231308
edit:G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Motherboard - ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
HDD - [strike]Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive[/strike]
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
edit:SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Case - COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Optical Drive -ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
PSU - CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
