Closed
Power supply installation in Antec 300 Illusion
  • Power Supplies
  • Cooling
  • Antec
  • Components
  • Product
Last response: in Components
December 7, 2011 12:56:54 AM
Is the 1/2" of clearance below the PSU sufficient to supply cooling air if the unit is mounted with the fan facing downward?
Thanks
More about : power supply installation antec 300 illusion
Best solution
a c 723 ) Power supply
December 7, 2011 1:13:48 AM
a b ) Power supply
December 7, 2011 1:39:36 AM
yep... although you should really mount it facing the inside but ya rolli is correct...
Score
December 7, 2011 1:44:51 AM
Facing upwards the fan would be fighting the GPU for air!
Many cases with bottom mount have a additional vent at the bottom for the fan, a handy person can easily do that mod to a 300.
Score
a b ) Power supply
December 7, 2011 1:59:34 AM
not really, ive done several antec 300 and 900 builds. I always installed the PSU fan side up, in fact I run the PSU fan side up in my corsair 400R. The real issue is dust so I always used a fan filter.
as far as effecting cooling, I've run stress tests using my corsair & antec PSUs in my corsair case with PSU fan side up and down. All temps where identical. Good cooling starts with a good cooler on the chip and proper case airflow.
Score
December 7, 2011 10:56:25 PM
Thank you all. I will be adding a vent and a filter to the bottom of the case to supply cooling air for the PSU.
Score
December 7, 2011 10:57:00 PM
Best answer selected by mkennedy_wa.
Score
