File Types Problem....Please Help...
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hi there. I'm kinda new here.
I messed with the file types in windows xp. i will describe the case:
i wanted to change the icon of a drive (C:\) manually, so i did these steps:
in explorer, tools-->folder options-->file types. there, i went to "Drive" and changed the icon to another one i had.
afterwards, i noticed that when i wanted to open, i.e., drive D from "My Computer", A Search window opened up with the option to search drive D.
the solution i thought of: went again to tools-->folder options-->file types, and in "Drive", besides the command "find" which can't be erased, i added the command "open" with "explorer.exe".
Now, every time i try to open drive D from "My Computer", drive D indeed opens but in a new window. In The "folder options", the general tab, the "open each folder in the same window" is enabled.
The solution i tried: i erased both commands (after backup) "open" and "find" from the file type "Drive" and everything is back to normal.
My QUESTION: is this solution is safe? or is there another safer solution (execpt system restore)?
Thank you.
i don't know what to do.
6 answers Last reply
More about file types problem please help
  1. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Hi,
    If this happens in future, type this in at Start >> Run and everything should come back to normal:
    regsvr32 /i shell32.dll
    Anando
    Microsoft MVP- Windows Shell/User
    http://www.microsoft.com/mvp
    http://www.mvps.org
    Folder customizations
    http://newdelhi.sancharnet.in/minku
    Protect your PC!
    http://www.microsoft.com/protect
    "Oren Farhi" <OrenFarhi@discussions.microsoft.com> wrote in message
    news:80C1E91D-2047-4C9F-814B-431016F059E5@microsoft.com...
    > another one i had.
    > enabled.
    > Thank you.
  2. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Thank you Both VERY MUCH!!!
    It works.
    "Anando [MS-MVP]" wrote:
    > Hi,
    > Anando
    > http://www.mvps.org
    > Protect your PC!
    > > another one i had.
    > > enabled.
    > > Thank you.
  3. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    In addition:
    You still missing the "Search" menu when you right-click a folder. Re-apply the "Find" reg you backedup and run the command Anando suggested. To know why this problem happened in the first place, see: http://support.microsoft.com/?kbid=321186
    Ramesh - Microsoft MVP
    Windows XP Shell/User
    http://www.mvps.org/sramesh2k
    The Parasite Fight:
    http://aumha.org/a/parasite.php
    "Oren Farhi" <OrenFarhi@discussions.microsoft.com> wrote in message news:80C1E91D-2047-4C9F-814B-431016F059E5@microsoft.com...
    Thank you.
  4. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Thank you very much for the information.
    Both answers work!!!
    "Ramesh [MVP]" wrote:
    > In addition:
    > The Parasite Fight:
    > Thank you.
  5. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    YW. Glad to be of assistance!
    The Parasite Fight:
    "Oren Farhi" <OrenFarhi@discussions.microsoft.com> wrote in message news:9662E406-FEE5-40AB-BE68-0B6D3A164C9C@microsoft.com...
    > In addition:
    > The Parasite Fight:
    > Thank you.
  6. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    You are welcome !
    Anando
    http://www.mvps.org
    Protect your PC!
    news:C5D67556-7E9B-4C43-9CC1-D5A667D24B17@microsoft.com...
    > It works.
    >> Hi,
    >> normal:
    >> Anando
    >> http://www.mvps.org
    >> Protect your PC!
    >> > to
    >> > another one i had.
    >> > "explorer.exe".
    >> > enabled.
    >> > type
    >> > restore)?
    >> > Thank you.
Configuration Customization Windows XP
