Sign-in / Sign-up
Motherboard problems no display
  • ASRock
  • Motherboards
  • Devices
  • Displays
September 16, 2012 5:28:27 AM
Hello,my motherboard dont display anything, just it have three long beep itry to chang all device like RAM and CPU ..... they are working in onther motherboard but not in min. what i can do?
More about : motherboard problems display
September 17, 2012 5:00:09 PM
Can you verify that the CPU and Memory are listed as supported for your motherboard?
It's also helpful if you post your system specifications.
m
l
September 18, 2012 2:51:17 AM
beep code states that there is no ram installed! check if ram sitted correctlly, check also if ram is listed in motherboards QVL,
m
l
