Problem with Homebuilt PC
Hello, I recently built my own gaming computer, it is my second build. It's been about 2 weeks since I built it, and lately I've been having problems when I try to boot it up after a complete shut off. What usually happens is that the PC will boot up for 2-3 secs and then shut off on its own, then reboot up, and it will work fine from that point on. But it takes it two attempts to boot properly and I am worried that it could be something serious. Specs are as follows:
CPU:Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
PSU: COOLER MASTER GX Series RS650-ACAAE3-US 650W ATX12V
RAM:G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Harddrive: HITACHI Deskstar 7K3000 HDS723015BLA642 (0F12114) 1.5TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5"
Mobo: ASUS P8P67 LE (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Video Card:SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16
Any ideas as to what could be causing the two attempts at booting?
thanks
4 answers Last reply
More about problem homebuilt
  1. Common issue with Sandy Bridge boards, especially ASUS. Make sure you have the latest BIOS update, but I don't think they have completely got this fixed quite yet.
    Mine does it too, but only sometimes, and I have not tried to a BIOS update yet.
  2. Any idea where I could download the BIOS update?
    By the way I appreciate the response!
  3. Nvm , found it. I forget Google exists sometimes lol.
  4. yeah, sounds like the mobo. A bios update may fix it, but you might have to live with it unfortunately.
Homebuilt Systems
