New GPU help(AMD Radeon 6670)
Hi. I recently got a new computer;
And Ive been having some trouble with the Graphics card(AMD Radeon 6670 1gb).
Before, I always got the message saying something like the catalyst control center doesnt support your current graphics adapter. please change your adapter in devices manager. In dxdiag and device manager, it only showed intel HD graphics family. It never mentioned AMD Radeon 6670. In catalyst control center, it showed intel HD graphics family also, and gave me very limited options to what I could do. So I uninstalled catalyst control center and the drivers.
I noticed after the fact I plugged the DVI cable from my monitor to my motherboard rather than the slots on my actual graphics card. I plugged the cable in to my gpu and nothing comes up, I figured this was the lack of drivers. So I went and downloaded this:
http://sites.amd.com/us/game/downloads/Pages/radeon_win...
I downloaded the Catalyst Suite.
Catalyst control center now doesnt appear at the beginning saying I have an error, but plugging the DVI cable into my Graphics card still displays nothing.
Any and all help is greatly appreciated. If I left out some important bits of information let me know, this is my first post and first time asking for computer hardware help. Thank you.
More about : gpu amd radeon 6670
Graphics card Expert
Delete the Motherboard drivers, and install the GPU ones.
Also be sure that all the parts in the computer are secure, because I've heard that sometimes parts come loose with Cyberpower PC's.
Graphics card Master
^ parts can come loose in any pc that is shipped to you. To the delivery man its just another box, and im pretty sure they dont read the "keep this way up" or "fragile" signs.
Related ressources
Well I checked to see if it was loose and it doesnt seem to be because when the power goes on, the cards fan spins. Will still try messing around with various drivers.
if your capable of doing so, remove the graphics card and just re-seat it in the slot firmly. Also, if you remove the gpu drivers, it will default to standard vga drivers, you will get display and you can then install the latest drivers.
The thing is when I install the new drivers, catalyst control center doesnt appear on the taskbar like it did before, no message pops up saying that it doesnt work with my graphics adapter, and the DVI port on my GPU still displays a black screen.
So I opened the case up to see if it was loose, it wasnt. I reinstalled Windows 7 because I thought that would do something, it didnt. Before when I was configuring this I tried using this program called DrvierSweeper I feel as though that may have caused this issue when I used it to remove my ATI drivers
I am having the exact same problem - booted up my computer with the monitor plugged into the onboard vga instead of the graphics card, and now when i boot it up with the monitor plugged into the graphics card it says no signal detected. this problem is coupled with the fact that the wireless card i bought was the wrong sort of plug in, so i have to return it and get the right kind.... /sigh. Is there any solution that doesn't involve downloading drivers off the internet?
I did this and it fixed the problem.
Thanks iam2thecrowe.
re-seat it in the slot anyway, just because it looks in there firmly doesnt mean the contacts are aligned.
Ask the community
