Solved
New I5 2500k/GTX 580 system. Cant decide on a monitor.
  • New Build
  • Monitors
  • Intel i5
  • Systems
  • Product
Last response: in Systems
September 8, 2011 6:09:46 PM
Hello Everyone, I just receive the parts for my first gaming build EVER lol.
MoBo: GIGABYTE GA-Z68XP-UD3P
CPU: I5 2500k
Cooling: Corsair H80
Memory: Corsair Vengeance 8gb 1600MHz
GPU: EVGA 580 1536mb
HDD: SAMSUNG Spinpoint 1TB 7200 RPM SATA 3.0
Case: Corsair cc600tm
I chose these components after reading reviews and receiving advise here on this forum.
I just have one more question... what monitor size do i get?
I already purchased an Asus 23" back lit LED @ 1080p max rez but am not sure if this monitor will be big enough for gaming. Although the price was great i can still fork out a bit more for a bigger size. I am looking at an Asus 25" monitor from New Egg ( i would like to stick with Asus if possible)
Do any of u have or are familiar with this monitor and is it good for gaming? or should i go bigger ( i will not spend unless it is a drastic difference)
More about : 2500k gtx 580 system decide monitor
Best solution
a b C Monitor
September 8, 2011 6:49:03 PM
There is no right size for everyone.
Many competitive gamers prefer a smaller screen because larger ones impair them. In an FPS, a very large screen will delay your reaction times as your eyes must scan more area. Similarly, a raid healer in WoW or other MMO has to see a lot of things easily. 20 health bars, threat meter, encounter notifications...
On the other hand, you have to consider how close your screen is to you. Also, what kind of work might you be doing on it? Multiple open windows?
I went from a 1680x1050 22", to a 1920x1080 24" monitor. I found this to be a good fit for me, but I think it might be too large for some. Others not large enough.
So, my opinion would be that you have the right size to start with. You might sit down in front of a larger monitor and think that it is more immersive, but does it really hinder your gaming performance? That's the question you have to ask.
September 8, 2011 6:56:13 PM
i had 2 24s but when i decided to go 3 for eyefinity i found that i could no longer get the monitors i had. so rather than having an oddball that i had to put a book under to make the right height i bought 3 new 27" monitors. now 24s feel small to me.
it might be a bit out of the range of what you were thinking but this is a very nice asus 27"
m
l
September 8, 2011 6:59:51 PM
If you had eyefinity, I'd go for 3 el cheapo 1080p screens around 23". Each would set you back about $130.
But since you are going for a GeForce, I'd try and get a 27" 1080p screen. Samsungs are good, as are LG. I have been very happy with LG screens of late. If you can afford it, a 30" 2560x1600 Dell IPS is a phenomenal screen. On sale, they would set you back about $1100
m
l
September 8, 2011 7:32:44 PM
I will be mostly a gaming on this system. i do not need to use it for work and do not do any editing and such. I just called NewEgg and they told me i can open it and try it out and can return it with in 30days as long as i dont send in the rebate. You say your 24" is a good fit for you. Is the 23" to 24" a significant diffrence? Do u do alot of gaing?
m
l
a b C Monitor
September 8, 2011 7:53:41 PM
Slight difference I would say, as they have the same res usually. I play FPS, RPG, Strategy (Civ V only), and used to play a lot of MMOs but not so much now.
My Current top 5 steam games are
Civ V
CoD Black Ops
Deus Ex
The Witcher
CoD MW2
My monitor is over a year old but was a good one at the time...
LG W2453V
http://www.lg.com/us/computer-products/monitors/LG-lcd-...
m
l
September 9, 2011 12:04:02 AM
Civ V
CoD Black Ops
Deus Ex
The Witcher
CoD MW2
LG W2453V
I went a head and opened the box, put the monitor on my desk, moved around on my chair, adjusted the monitor, and adjusted my chair lol. I have a small desk as my set and i realized that if i get a bigger monitor i will not have enough distance from it. i am also thinkgin about what u said regarding FPS games and being able to scan the screen faster. I will keep this monitor after all. Besides, if i ever put in a 2nd card it will be cheaper to buy 2 more of these than the bigger size.
Thank you for your help :)
m
l
a b C Monitor
September 9, 2011 12:11:08 AM
No problem :)  Last time I played WoW, I had to actually suck in my GUI components and leave a wide margin on the outside... so that I could see everything I needed to see in a raid without moving my head.
m
l
September 16, 2011 5:20:16 PM
Best answer selected by kancer526.
m
l
