Max power consumption
  • Power Supplies
  • Power Consumption
  • Components
Last response: in Components
December 9, 2011 6:28:29 AM
hey guys i have this system
i5 2500 non k
intel dh67cl mobo
8 gb ddr3 1333mhz kingston (2x4gb)
xfx 6950 1gb card
xfx 750 watts unit
1 500 gb hdd
mid tower case with 1 fan (led) 120mm
the question is wat is the max load of this system(gaming) theoratically i know that 750 w unit is plenty but im asking because i have a 935va ups (530 watts) and need to know if it is enough to hold my system
More about : max power consumption
a b ) Power supply
December 9, 2011 8:20:57 AM
Your system will draw about 450W at max load. The UPS will do fine.
Nice PSU, by the way.
m
l
December 9, 2011 8:40:52 AM
^ thx man i always tend to overkill regarding psu's which i consider to be the most important part of the pc
m
l
a c 1218 ) Power supply
December 10, 2011 7:02:46 PM
Actually the system unit should be drawing less than 312 Watts at the wall plug under full CPU and GPU load as shown during Guru3D's review of the Radeon HD 6950. They use a system configuration that consumes more power than yours but it gives you an idea of what the realistic power consumption may be.
Is your monitor also being plugged into this UPS? What is its power draw from the AC outlet? You will need to add that on top of the 312 Watts for the system unit.
m
l
