Started on my first build and so far everything was going ok except until I got to the issue of connecting my case fans to my mobo. My case is the Azza Spartan and my mobo is the Gigabyte Z68X-UD3H-B3. The case fans have a plastic plug that it is a 4 pins and the mobo has only one 4 pin and it is MUCH smaller then the case fan plug. All the other fan plugs are 3 and small also.
Thanks!
Thanks!
