ATI RADEON 5870 problem plaese help me
hi guys im wondering if my psu is affecting my performance because my pc somtimes startup fine but then when i enter games i lag extremely then i restart my pc and its fine now im wondering if its the psu or not plz help
system specs :
cpu:intel qaud core q9550s
memory:2X 2 GB DDR2 800 MHZ
GPU:ATI Radeon 5870 1gb ddr 5
case:cm storm scout
cooling: cou cooler v6gt
Psu: gigabyte odin 585 with only one pcie connector! i use extensions provided with gpu
please reply as soon as possible
Related ressources
Graphics card Master
-_-haha said:
wht do u guys mean fffs plz tell me
No one here is obliged to help you and using 'text speak' and acronyms such as 'ffs' are reason enough for me to delete this thread, so roll your neck in and exercise some patience.
-_-haha said:
monkey wht do u mean no one here is abliged to help me
Just exactly that, no one who use this forum is paid to do so thus there is no obligation to post anything at all.
-_-haha said:
oooooo ok i under stand but please help me if u can
I would suggest that your problems may be driver related but making such suggestions always seems to get the ATi fans worked up into a bit of a frenzy.
-_-haha said:
no no im cool but what drivers because i have latest drivers for everything
Try the older drivers and see if one them makes the problem go away.
If you want to find out if the card is throttling, download MSI Afterburner or GPU-Z and monitor the clock speeds while you attempt to play. See if the core clock is dropping or not.
-_-haha said:
no monkey have had the old drivers installed aswell also happened and would my card throttle because of psu
Weak PSU's tend to cause BSOD's, lock up's and/or error boxes popping up, throttling back when it shouldn't is a driver or BIOS (on the device) issue.
-_-haha said:
my pc did bsod but it was because of chipset drivers ill role back my drivers and see if tht helps but do u think i should get a new psu just incase
A darn decent PSU can never be a bad investment IMHO.
Corsair is a reputable brand, and 600W is a good size for today's single GPU systems. It should give you some room to protect yourself and overclock should you choose.
I believe mm was saying that he also likes Corsair, as he's had great success with them.
Ask the community
