problem with system restore
Archived from groups: microsoft.public.windowsxp.customize (More info?)
i have xp pro and when i go to use system restore it goes through the
motions but wont restore the system to any time or date what is causing
this?
please help
3 answers Last reply
More about problem system restore
  1. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    > causing this?
    Your system restore may have gone.. south.
    Hopefully you don't NEED to restore right now and your problem can be
    resolved another way.
    However, you can get your System Restore back up to speed by turning it off,
    reboot, turning it on and making a manual restore point..
    Turn off System Restore.
    http://support.microsoft.com/?kbid=310405
    Reboot.
    Turn on System Restore.
    Make a Manual Restoration Point.
    http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/xpsysrst.mspx
    That will erase all previous restore points, but if they don't work
    anyway......
    (Do that whenever you think about it too..)
    <- Shenan ->
    The information is provided "as is", with no guarantees of
    completeness, accuracy or timeliness, and without warranties of any
    kind, express or implied. In other words, read up before you take any
    advice - you are the one ultimately responsible for your actions.
  2. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    Hi
    One or more of the System Restore files could have been corrupted - try
    turning SR off/on - but I'm afraid that you will lose any existing
    checkpoints:
    Right click My Computer, select Properties and then the System Restore tab.
    Enable 'Turn off System Restore on all drives' and reboot your PC. After
    that 1st reboot go back into SR and disable 'Turn off System Restore on all
    drives' and reboot your PC again. After that 2nd reboot you should have one
    new SR checkpoint.
    Will Denny
    MS-MVP Windows - Shell/User
    Please reply to the News Groups
    "david damelio" <ddamelio@tampabay.rr.com> wrote in message
    news:eNko0hkaEHA.212@TK2MSFTNGP12.phx.gbl...
    | this?
    | please help
  3. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    I used to have a problem, too, but my system restored my question. Now it Works, maybe you have encountered such a Problem. I'm not sure, does it Work, now?
    > > causing this?
    > Reboot.
    > anyway......
    > <- Shenan ->
Configuration System Restore Microsoft Customization Windows XP
