Tom's Hardware > Forum > Mobility Technologies > Bluetooth > problems with voice gateway
Forum Mobility Technologies : Bluetooth - problems with voice gateway
Archived from groups: alt.cellular.bluetooth (More info?)
i have the latest widcomm drivers installed. im using a d-link USB BT
dongle. i set up a voice gateway to my SE T616 from my laptop. I use the
laptop to dial out, the cell phone dials and connects. i can then hear the
ringing through my laptop. after a couple of rings, i hear the noise
associated with the voice gateway disconnecting from my phone. any
thoughts?
Sponsored Links
actually after a bit more playing around, it seems that its not
disconnecting, its just going static and then the voice cuts in and out. i
called my voicemail from my phone and it autoconnects to the PC and i can
hear the voice over the PC asking me to enter my PIN but it cuts in and out.
very difficult to understand.
"Rob" <rob@nospam.com> wrote in message
news:oQptc.24732$rb.14583@nwrdny03.gnilink.net...
the
> thoughts?
Reply to Rob
Voice gateway is heavily affected by CPU usage on your computer. Check that.
Also, it's not the best sound system... A headset would be more appropriate,
but that depends on availability of course.
Mauricio Freitas, Microsoft MVP Mobile Devices
Bluetooth guides: http://www.geekzone.co.nz/content.asp?contentid=449
Performance Centre (Pocket PC reviews):
http://www.geekzone.co.nz/content.asp?ContentId=2028
Handango discount: http://www.geekzone.co.nz/handango_code.asp
news:y2rtc.24891$4%3.1854@nwrdny01.gnilink.net...
i
out.
the
> the
> > thoughts?
Reply to Anonymous
ah, you just hit the nail on the head i think. if its CPU it requires, then
Im SOL. My laptop is a heavily stressed 300mhz p2 running XP pro with
128meg. i had to use a margi card just to get it to play DVD. one more
reason to upgrade.
"Mauricio Freitas" <dr.emailposter@nowhere.invalid> wrote in message
news:K3stc.4273$FN.451556@news02.tsnz.net...
that.
appropriate,
> i
can
> out.
> the
hear
> > the
> > > thoughts?
Reply to Rob
> reason to upgrade.
XP in 128 mb is enough reason to upgrade........Ouch. it boots but I
doubt it'll do much after that.:)
I have a 366 mhz laptop with 96 mb running linux. It does quite well
for what I need.
Reply to Anonymous
actually it does pretty well, considering. its in my car connected to a 7"
touchscreen and works fine for GPS, MP3, browsing the web, DVD is ok with
the margi. i was just trying to use it for integrated hands free cellular
(auto shutoff of sound during incoming calls, etc). ebay time.
"Mark E. Daniel" <mark@atarimax.com> wrote in message
news:2ho9n3Fet9duU2@uni-berlin.de...
then
> > reason to upgrade.
> for what I need.
Reply to Rob
There are 1070 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
