Okay so these are my specs:
Motherboard:Asus P5G41-M 775 socket
CPU:Intel core 2 Duo E7600 3.06 Ghz
GPU:Sapphire Ati Radeon HD 5570 1024 mb
Ram:3gb ddr3
What should I upgrade first? The motherboard & CPU or only the GPU? I plan on running it at a resolution of 1280@1024 with setting set to High.I currently run it at 1280@1024 with all settings set to low and It doesn't get past 35.
Can you tell me guys what to choose and some good components?
BUDGET:250$/186€
Thanks!
Ram:3gb ddr3
BUDGET:250$/186€
Thanks!
