How to get asus m4a88td v evo optical audio 6 channel output? toms hardware
im not getting a surround output(i.e. 6 channel output) when connected through optical audio cable to my home theatre system
and getting only 2 channel 16 bit 48khz.
pls help me guys.
my pc is providing a 2 channel out.no choice for 5.1channel
how to make it possible?
11 answers Last reply
More about asus m4a88td optical audio channel output toms hardware
  1. you might want to check if your computer even supports it.
  4. that didn't work
  5. thanks for responding brother upendra.
    pls tel me to how to check that my computer supports it.
    i connectd my home theatre surround sound system to my computer using an optical audio cable.
    In sound settings from control panel,i selected the properties of hd optical audio.there under advancd tab only stereo setings are displayed(2 channel 16bit 48khz).and the test tune works perfectly in 2 speakers.but my other 4 speakers are not engaged in that test proces.
    dear brother pls giv me a solution for that.
  6. thanks for responding brother upendra.
  7. thanks for responding brother upendra.
  8. it sounds like your computer doesn't even support 6.1 surround sound
    but lemme see your specs
  9. asus m4a88tdv evo usb3
    amd phenom ii x4 840 3.2ghz
    adata 2x 2gb ddr3
    seagate barracuda 500gb sata
    samsung dvd writer
    sony dav dz370 home theatre
  10. guys pls help me in this situation
Asus Hardware Audio Motherboards
