I recently built my first PC and I'm having problems with my mobo. It's an ASrock z77extreme4-m card and when I put my GTX 670 card in the PCIe 3.0 slot Windows boots and then slowly starts to freeze. I contacted ASrock tech support and they said to switch the link speed from Auto to Gen1 under the BIOS for the PCIe 3.0 slot. That solved the problem, but doesn't that mean I'm only running at Gen 1 speeds (8x)? Maybe I'm confused about that, but I feel like that's only a temporary fix and isn't actually solving the PCIe 3.0 problem.
Also, when I put the GPU in the PCIe 2.0 slot, I have no problems, so I don't think the problem is on the GPU end
My full specs:
Intel i5 3570-k
8 GB Ram
620w Seasonic S12II power supply
ASrock z77extreme-4m Micro
60gb OCZ Agility 3 SSD
500GB Seagate HDD
Windows 7 64-Bit
I'd appreciate any and all help!
My full specs:
Intel i5 3570-k
8 GB Ram
500GB Seagate HDD
Windows 7 64-Bit
