No Sound From Rear and Front panels T_T
my specs :
CPU:Intel Core i5-3570K Ivy Bridge OC 4.2 GHz
CPU COOLER:ZALMAN CNPS9900ALED 120mm 2 Ball
MOBO:ASUS P8Z77-V PRO
GPU:Gigabtye GTX 670 OC Version
RAM:G.SKILL Ripjaws Series 8GB DDR3 1600
PSU:CORSAIR HX850W
CASE:Rosewill BLACKHAWK Gaming ATX Mid Tower
HDD:Seagate Barracuda1TB 7200 RPM 64MB Cache SATA 6.0Gb/s
SSD:o CZ Agility 3 64GB SATA III
ODD:Samsung SH-222AB
OS:Windows 7 Ultimate 64-bit
1.i already re install the OS even the drivers no luck
2.i pretty sure i connect all cables in right place
3.i tried different speakers and headphone from rear and front panel no luck :cry:
any suggestions guyS?? :cry:
Related ressources
That's bad. The audio jack is screwed up probably.
BUT, if the front panel isn't working either. Then it must be the drivers. OR the whole board's audio capacitors :o
Do you have any other OS installed?
Ask the community
