Hi everyone,
I have decided to upgrade my Intel Quad Core (Q9300) based hardware to a more recent system. Basically I use my computer to study virtualization tech, play games and enjoy multimedia capabilities.
Recently I purchased following components:
Asrock Fatal1ty 990FX Pro Mobo Rev 1.03 (DEFAULT BIOS)
AMD FX-8150 CPU (Stock Fan)
Corsair Vengeance 1866 MHZ DDR3 RAM 4 GB x 4 = 16 GB Total (4 sticks of 4 GB)
600W Xilence XP PSU (Tested working from old system)
Cooler Master Stacker Tower Case
HD6850 GPU (Tested working from old system)
I have two questions:
1) Although i tested everything I can't get it boot successfully. No post, no display, no beep codes if speaker is attached and DR Debug LED displays only 00 as code and this code never changes.
My conclusion is that this mobo might need bios update to support FX-8150.
I tried reseating components and mounting mobo in mobo box instead of coolermaster case, I also ordered a second hand Sempron CPU to update bios, if this will save me.
2) Can i use Zerotherm Nirvana NV120 that i used to cool Q9300 CPU, at this mobo within FX-8150 cpu instead of stock cpu fan?
Any comments?
Any comments?
