Will an 8800GT/GTX (G92) water block fit an 9800GT single slot card?
Does anyone know for sure if an 8000GT/GTX (G92) water block VGA will fit a EVGA 9800GT single slot card?
14 answers Last reply
More about will 8800gt water block 9800gt single slot card
  1. The 8800GTX was not a G92, that said if you meant the 8800GTS G92 then the block should fit as the 8800GT and the 9800GT are one and the same just as the G92 8800GTS is the same as a 9800GTX.
  2. well i had a 8800gts and i took the water block off it and put it on my 9800gt and it wouldnt fit properly. i thought what the hell and it ran for a month and then blew up so i would advise against it
    What were the differences between the two cards?
  4. the memory chips are in slightly different places so the block wasnt covering them and also it bent the board into a slight curve.
    Why did it bend the board?
  6. becuase the block doesnt fit snug to the card so it had a pressure point in the middle of the board which bent it upwards
  7. So the mounting holes on a GT and GTS board are slightly different?
  8. yes they are
  9. Well as the 8800GTS (G92) and the 9800GTX are one and the same I would hope that problem doesn't rear it's head but looking at pictures of the 8800GT and 8800GTS G92's they did look they shared the same PCB.
  10. yeah thats why i swapped them over but i wish i hadnt now. I thought they were the same and it looks like the same pcb but they have small changes that make swapping the coolers incompatible
  11. I had similar when I swapped the coolers over from my 7900GT's to the 8800GT's but I was luckier in that case because they did have exactly the same PCB.
  12. yeah they did have and alot of articles do state that the 8800gts and the 9800gt have the same pcb but the 9800gt is slightly different. I found that my 8800gts was more powerful than my 9800gt aswell becuase the 9800 had some transistors and stream processors deactivated and taken out
    Yes, the 8800GT and 9800GT have 112 cores and the 8800GTS and 9800GTX have 128 cores. So it would be more powerful just as a 9800GTX is going to be more powerful than an 8800GT.
  14. what about this Alphacool NexXxoS NVXP-G Nvidia 8800 GTS Waterblock?
Graphics Cards Gtx EVGA VGA Graphics
