Alright. I bought a premade computer from best buy and everything worked ok. I then purchased a new video card and power supply, instaled them and everything continued to work fine. I then purchased the antec nine hundread two case and moved everything into it and now nothing works. Moved everything back into my other case and nothing still works.
I have a corsair 700w psu, i7 cpu and a asus p8h67-pro motherboard. You can look at the specs from the best buy website. its the 849.99 i7 geforce 560 model.
Now i have done the breadboard thing i have heard about here and still nothing. I have only the 8 pin and 20-24 pin plugged in. The only way to turn on my psu and the fan to my cpu is by shorting it with a screw driver because one i plug in the POWER SW wire to the POWER SW connectors the power button on the case dosnt turn it on. but once i short it with the screwdriver the power button will turn everything off. I get no beeps or sounds and i get no reponse at all on my monitor. I have spent countless hours over the pat couple days researching this and it seems nobody has had the same problem. What should i do?
