OK so System specs are here
2 radeon 6870s in xfire
8 gig 1366 mhz or around there
500gig hardrive
As-rock p980 fx or something like that not sure
and a phenom 2 x4 965 @ 3.4
Also 650 watt power supply. Yes i know this is to little power im getting a new one in a week
So anyway i think this may be a defective cpu or just not enough power cause Ive done benchmarks and benchamarks on my cpu and gpu heres a few
3d mark 11 gpu 8000 something
cpu 4000 something
ill play gta 4 with a trainer spawn 100 people and it will just crash it stays at 30 fps on max but then if i spawn to many it crashes same with skyrim probably an game engine failure idk. But i just wanted to know if theres like any solution to making your cpu work harder like forcing it to because even in furmak and the one with the floating island it stays around 30% usage?????????? Help is aprecciated.
500gig hardrive
cpu 4000 something
