Hyper 212 plus retention plate screw tightening problem
  • Components
Last response: in Components
December 13, 2011 12:22:27 AM
Im currently installing hyper 212 plus on my mb m4a88tm
Phenom x4 965
I have seen lot of tutorials ,i know the procedure exactly
But i cant tighten the four screws of the retention plate to the nuts from the back panel
I can tighten maximum of 3 screws ( only by tight streching )
For the fourth screw i cant even strech with great pressure
I have repeated the step again and again as told in some videos and website
But finally it alll ends as i said
Should i give even more pressure and connect the fourth screw
( will that affect my processor , or board)
Should i work with 3 screws connected ,
Im in urgent help,,,, plz some expert advice
More about : hyper 212 retention plate screw tightening problem
December 13, 2011 12:51:12 AM
You shouldn't be tightening down any of the screws until they have all be started. Undo the other three screws and start all 4 screws BEFORE tightening any one of them. It is a bad idea to have a 500g heatsink hanging off of your board and applying an uneven load to the board because you only have 3 screws in, it wont be making good connection with the CPU and you will be putting extra strain on the motherboard which will either hurt the board or cause the mounting system to fail prematurely.
m
l
December 13, 2011 1:03:34 AM
I did not start tightening i cant start the fourth screw anyhow
I did only as u said
But that is not working
I even saw if any error in backplate or nuts , result negative
m
l
December 13, 2011 1:09:40 AM
ive hear other people have a similar issue with the 212 (its rare but not uncommon). its simply not compatible with every single mobo, the screws are too short for a small number of them. can you return the cooler?
m
l
December 13, 2011 1:20:01 AM
Wow
Guys my father helped me
Im too weak to streach it
My father streached the retention rod
Works done
:D
m
l
December 13, 2011 1:22:18 AM
1and0 said:
Wow
Works done
:D
gratz enjoy
m
l
