I put this together last night:
Sabertooth z77
i7 3770k
Cooler master 850w
gtx 670
gskill ddr3 4x4gb
hard drives and odd etc
inside a coolermaster haf 932
When I plug the power cord into the psu and flip the on switch, a green light lights up on the mobo. Pressing the power button does absolutely nothing. So I unplugged and checked all the connections. Power switch is plugged in, atx power is in etc. I also did the paper clip test on the psu which works fine. If the memory or cpu was seated incorrectly, this would be indicated by leds on the mobo, correct? Stand-off bolts are in place for the mobo. MemOK! button does nothing and the bios flashback led blinks on the back panel. Any thoughts? Sorry if this is sort of jumbled together, it's been a long night.
The psu had the standard atx power cable, but not an 8-pin connector. Instead it was 2 4-pin connectors that were separated. The manual shows using 1 8-pin connector or 1 4-pin connector. What do I do with this?
Sabertooth z77
i7 3770k
Cooler master 850w
gtx 670
gskill ddr3 4x4gb
