Sennheiser pc 360 work with integrated sound card?
Last response: in Components
hi i wanted to know if Sennheiser pc 360 headphones work with integrated sound card?
my pc is
Intel® Desktop Board DX58SO2
Intel Core i7-975 Extreme Edition - not overclock
120 SSD Intel Harddrive - Main Harddrive for windows
500g Harddrive -- Gaming / Movie Harddrive
24g Ram
Nvidia 295 gtx
8T External Network Storage System WD ShareSpace x2 - Movies / Anime
would my pc be good enough to use the Sennheiser pc 360 or would i need to go buy a sound card?
It will work with the onboard audio. No need for an amp, that headset is designed for gaming use on a PC...
That headset is basically the open version of the PC350 I have been using for years.
If you have hearing problems (or just want to blow your head off) you might need that external amp.
Ask the community
