Sound Card for Alienware M15x
  • Sound Cards
  • Sound Blaster
  • Alienware
  • Components
Last response: in Components
December 13, 2011 6:32:04 AM
Looking for a sound card / external sound card for the Alienware M15x
Only have two main choices, i try to find the best of the best, but in terms of notebook sound cards, it's very limited compared to desktop PCI-E's.
1. Creative Sound Blaster Audigy 2 ZS Notebook Sound Card PCMCIA
http://www.amazon.com/Creative-Blaster-Audigy-Notebook-...
24 Bit / 192KHZ Output & THX Certified
Studio Quality Sound, Low-Latency Recordings, and High-Fidelity Inputs
2. Creative Sound Blaster X-Fi HD Sound Card powered
http://us.store.creative.com/Creative-Sound-Blaster-XFi...
24 Bit / 96KHZ Output & THX Certified
The first sound card beats the external one in terms of 192KHz > 96KHz, but came out before the second so perhaps the second one is more up to date? which do you think is the clearer choice that i should make? I have a Blue Yeti Pro Microphone that produces 24 bit 192KHz recorded sounds thus i was looking all the way up to 192KHZ but don't know if it would yield any better quality.
More about : sound card alienware m15x
December 13, 2011 6:40:04 AM
IIRC there's little difference in audio quality and SNR between the x-fi and audigy series. So go with which ever suits your needs better.
m
l
December 13, 2011 6:46:45 AM
in terms of what suits me best, i'd say the one with 192KHz output which should be the better sounding one right?
just a little sad that it doesn't have the cool look and pluggins like the X-Fi HD one.
Just wanted a 24 Bit 192KHz to grasp the full sound quality being produced from my microphone. Perhaps there's an even better card i might have overlooked.
m
l
December 13, 2011 6:17:18 PM
Exactly the stuff i'm looking for!
Sadly the U3 only does 48KHz @ 16bit, and after i saw Xonar Essence One i was blown away. Too bad the cost was a little over $500...
One thing that would suck for using a usb option is that my M15x only has two USB 2.0 slots, one connecting the usb microphone, the other to my razer mamba 4G mouse.
Is there any way to e-Sata to usb or something? or any other accessories that could give me more usb ports?
m
l
