Overclocking G.Skill RipJaws X - 1600Mhz (Maximus V Extreme)
Hey Guys,
I have some questions. I'm running 2 different RAM kits which are -
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
and
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568
Please note that I am facing NO stability issues at ALL! I'm just experimenting with my timings and all - I managed to get to 2000Mhz each with 12-12-12-24 1T - Is that good? I faced some stability issues and 1-2 BSODs when I was running it. Normal browsing and stuff was fine. Is there ANY way to reach 2133? Any at all? Or should I just continue trying to make my system a bit stabler while running at 2000?
Here is my System Spec -
Intel Core i7 3770K Ivy Bridge
ASUS Maximus V Extreme Z77
G.Skill RipJaws X 8GB (4GBx2) 1600Mhz
G.Skill RipJaws X 16GB (8GBx2) 1600Mhz
Sapphire HD Radeon 6950 OC
WD Caviar Black 1TB
Seagate Baracuda XT 1TB
WD Caviar Green 1TB
WD Caviar Green 1TB
Corsair Extreme Liquid Cooling - H100
CoolerMaster Extreme 700W PSU
Asus 24X DVD RW
Corsair Carbide 500R
ASUS Wifi/Bluetooth 4.0 Combo (With mobo)
SIX Fans (5 - 140mm, 1 200mm)
Thanks in advance.
2 answers Last reply
More about overclocking skill ripjaws 1600mhz maximus extreme
  1. as far as i know thats a bad decision putting diffrent modules like that
  2. Is there any reason why you would need to overclock ram?
Memory Product
