Coolermaster power extreme plus 500w installation guide
  • Power Supplies
  • Cooler Master
  • Dell
  • Power
  • Components
Last response: in Components
December 13, 2011 5:17:47 PM
Hello,
do you have installation instruction for the coolmaster extreme plus 500w to be installed into the Dell Studio 540?
More about : coolermaster power extreme 500w installation guide
December 13, 2011 7:50:24 PM
Im having troubles with which wires go where. there seems to be many more than is needed.
Thanks!
m
l
December 13, 2011 8:43:14 PM
There is likely more connectors than you actually need.
here is a diagram of your motherboard with labels:
http://support.dell.com/support/edocs/systems/STD540/en...
you need to connect the 24 pin motherboard power connector (the big one) to #9
the cpu power connector is on its own wire. there are 2 of them each with 4 pins next to each other. connect one to #35.
your drives probably use sata power connectors. they are the skinny/flat ones. there are 3 on one wire.
if you have a video card it might need the pci-e power connector, it will plug into the video card. its on its own wire. not all video cards require one.
m
l
December 13, 2011 8:50:31 PM
also, the connectors only go in one way. look at the shape of the pins on the connector and match it up with what you're plugging it into.
m
l
