Tom's Hardware > Forum > Storage > Hard Disks > WD HDD Problem
I have a 20gb Western Digital HDD, but am experiencing some rather disconcerting problems. I have a 700 classic athlon and 64mb of cheap ram (will upgrade soon). For awhile I oc'd my system through FSB achieving 110FSB, but my RAM PC133 RAM couldn't take the increased frequency, so I run it at 100. Initially I noticed that drive was getting really hot, so I bought a HDD cooler form coolerguys.com. When before it tooke maybe 50 secs to boot up it now takes almost 2 mins. When the Win98SE boot screen is up there HDD activity light isn't active for almost a min. Boot up time I can live with, crashes I cannot for it crashes after almost everything. I tried re-formatting and repartitioning using FDISK, but no good, each time I reinstall windows it seems to get slower. No bad sectors are being shown, but I beleive it is a mechanical failure. Any suggestions, or should I just get an IBM? Thanks
Sponsored Links
I wont comment on 133ram not being able to take 110mhz :)
I would see if you could borrow a hdd from someone like an 8-20 gig and try that, you might be having a hdd controller failure or something similar. Not nec. a drive failure
Bored,Certified Tech
although at 100$ for a 20gig you can always get 2 20gigs and a raid card ;)
Reply to Raistlin
My PC133 can't take 149mhz, it can run at 133. Geuss I'll just get an IBM.
Reply to nyteskyy
How do you get 149 out of 110?
you are either running it at 100*7 for the processor
or it is an independant clock so changing the 100 to110
would make no difference
i can overclock my processor and it has absolutely no effect on the memory because they are independant clocks
you dont just take 133 X1.1 (which is 146 anyway not 149)
I am unclear where this magical 149 came from please clearify.
Reply to Raistlin
There are 525 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
