New Build - but have some questions first
Ok, so I am building a new pc, and have a couple of questions first
Do I need the MSI GTX 580 lightning extreme, or will the non-extreme do just fine? I will only be using one monitor, and will be recording with fraps, I also would like it to be future proof to an extent :)
Does the NZXT phantom have good airflow, or should I go with the AZZA HURICAN 2000?
Thanks
-adren
5 answers Last reply
More about build questions first
  1. Anyone?
  2. No one?...
    Thanks
    -adren
    lol, I'll help you.
    If you want superior airflow, and don't mind the sound, go with the Antec Lanboy Air: that thing can hold up to 15 fans!
    If you want quiet: use the Antec 1200V3, I've read a lot of good reviews
    Out of your two choices: Azza Hurican.
    Thanks
    -adren
    As for the graphics card: non-extreme or an EVGA.
  5. Personal experience with the phantom is it's quiet and has good airflow, in my opinion all cases comE down to looks, and personal prefrence.
New Build New Build Systems
