PC VGA output to VGA- DMI adapter connected to DVI-HDMI cable to LCD Monitor shows "No HDMI Signal" on LCD Monitor. I have confirmed the following:
1. VGA - DVI adapter works from PC to DVI connection on LCD monitor
2. DVI- HDMI cable works from cable box & DVD player to LCD monitor
3. PC VGA output to LCD monitor VGA input works fine.
But LCD Monitor shows "no signal" when using the VGA - DMI adapter connected the DMI-HDMI cable. I've also checked out 2 different DVI - HDMI cables and confirmed both work properly when
connecting to either a cable box or DVD player.
So, all the cables, adapter, PC, and LCD monitor work, but not through the PC VGA output.
Does anyone have any suggestions on where I go from here?
Thanks
Thanks
