Okay so I decided it would be cheaper and better for my knowledge to build my own computer. I want it to cope as a family PC aswell as being good for gaming, school work, etc. I want to know everything I need to buy to build the PC and this is what I have so far.
P.S. I havent chose a case yet, some recommendations for that aswell as possible modifications for the parts would be great! As you can tell I want the computer to be quiet, cheap, with high quality parts (hard to achieve )
Computer Part-----------------------Price £
ASRock Z68 Pro3--------------------89.36
Intel i5 2500k-----------------------166.14
Arctic Cooling
Freezer Xtreme----------------------25.50
Arctic Cooling
MX-4 Paste---------------------------2.42
Windows 7
64-bit---------------------------------73.99
Lite On Silent
DVD-RW----------------------------- 24.64
650W Alpine
Silent PSU---------------------------23.45
8GB Corsair
DDR3 RAM----------------------------35.93
Samsung 1TB
HDD OEM----------------------------45.95
2 x Sata data cable
(hdd + dvdrw)----------------------2 x 0.88
CASE??------------------------------????
So far the total is £489.14
Seriously though if you think I am missing anything please tell me I dont wanna buy all this for it not to work D:
P.P.S. I havent chose a graphics card yet because the board should let me use integrated for a while and I can get a graphics card when its all sorted. (The GPU I have in mind is the Sapphire HD 6670)
Arctic Cooling
Arctic Cooling
Windows 7
Lite On Silent
650W Alpine
8GB Corsair
Samsung 1TB
2 x Sata data cable
