Will the asrock x79 extreme4-m work with a 3770k processor?
Hi There,
I am a bit of a noob ( A real noob :-) ) and this will be my first build and I have just bought the i7-3770k processor and I was give the asrock x79 extreme4-m board as a gift and after checking the asrock site under cpu support list I do not see the 3770k listed :-(
So am I correct in saying that the board won't work with the 3770k?
Thanks for your input guys
BR
Jack
Thanks for your quick response geekapproved! So it's either a new mobo or a new processor right?
If processor am I right in saying either the 3930k or the 3820k will work?
If a new board then any of the z77 boards will work? For example the asrock Z77 Extreme4-M board will do?
Again thanks a lot for your input geekapproved!!
Related ressources
You should have mentioned that in your first post, I would have told you to return/sell the 3770K and get a 3930K.
However you never mentioned what your plan to use the pc for, so really can't suggest one over the other.
Yeah you are right I should of mentioned it!
I am a bit of noob at this so bare with me!!
I now have the Asus mobo in my possession as well as the Asrock x79 board... So I could get the 3930k for the Asrock but I am a bit concerned of it's size and it's features for the 3930k :-)
But then again it will do me just fine if I overclock the 3770k with the asus board but then from what I read if you overclock then you need to have watercooling??
I don't know whether that is a new topic I need to create??
And an update on my system: I am currently purchasing two 120 corsair force 3 ssd drives and I think I will raid them what do you think?? Not much performance gain I've heard?? That might also be another topic I need to create?? As I said I am new at this :-))
Ask the community
