Hello,
I am the happy owner (untill now) of a Asus Mobo P8-H77-i, while I do like the motherboard it is inface causing me some problems.
I tried installing my AMD HD 6970 card into the PCIE (only one, as it is a mITX), it shows up fine however: It is only able to give me x4, not the promised x16. I have tried a lot:
-Reseating again and again
-Cleaning the PCIe slot really carefully
-Turned of the auto power saving option (the one which reduces PCIe speed) in windows 7
-Both GPU-Z and CPU-Z gives me the same reading "Link width x4, Max supported x16" and "PCI-E 2.0x16 @ x4 2.0"
-Used the PC diagnostics tool provided by Asus and it passed the PCI-E slot.
-Updated every driver for chipset and BIOS
By now I had reached the conclusion that the GPU must have been a bust, however it worked on my friends mITX motherboard (Zotac Z77) with x16 PCIe bus.. so Im very confused and frustrated.
-Brage
-Brage
