Closed
Power
  • Power Supplies
  • Crossfire
  • Power
  • Components
Last response: in Components
December 15, 2011 5:59:49 PM
I am going to start my first build and I will have 2 6950's crossfired they are each dual 6 pin cards.The question I have is do I need a power supply with 4ea 6pin connectors or one with just 2 connectors? I see many supplies labled crossfire ready or crossfire certified and they only have 2ea 6pin connectors do they all have splitters on the ends or something?
More about : power
a b ) Power supply
December 15, 2011 6:28:05 PM
The easy answer is yeah, you'll need 4x 6pin or 6+2 pin.
Keep in mind not all cards require 2x of each so there are sli/crossfire psu's that can claim certified or ready that only have 2. For posterity sake it should be noted that there are molex to pci-e converters but really, just stick with the easy answer.
Score
Best solution
a b ) Power supply
December 15, 2011 6:31:22 PM
most PSU that only come with 2x PCI-E power connectors and SLI/CF certified (they tend to be 500w-650w) are for lower to mid level cards.
although you could use molex connectors, I would advise a PSU with 4 x PCI-E power connectors (they can be 6pin or 6+2, or any combo of the two) with at least 55a on the 12v rail (usually 700w+) for your set up.
December 15, 2011 7:52:23 PM
Best answer selected by darksbain.
Score
December 15, 2011 7:55:24 PM
thnx I was looking at the corsair tx 750 or gs 800 will wait for a newegg price break on one or the other.
Score
