PSU buzzing noise @ connection
  • Power Supplies
  • Connection
  • Components
Last response: in Components
December 15, 2011 8:53:08 PM
So I've recently noticed that my PSU makes a soft electrical buzzing noise that you can hear if you get close to where the PSU is connected to the plug thing. I was just wondering if this is normal because this is a 3 week old power supply.
Thanks.
More about : psu buzzing noise connection
a c 723 ) Power supply
December 15, 2011 10:08:06 PM
It is not an uncommon problem if you google PSU coil whine. Quality PSU's are less likely to have it and people have successfully RMA'd them for that reason.
m
l
