rEcR8Z Honorable Aug 16, 2012 113 0 10,690 Sep 26, 2012 #1 Adapter for the power/led/reset cables which connect to the mobo. I cant find them since I dont know the correct names. Fast answer would be great
mouse24 Splendid Nov 30, 2010 4,389 0 23,960 Sep 26, 2012 #2 What do you mean by adapter? replacement buttons? extension cables? I've always thought they were simply referred to as front panel connectors Upvote 0 Downvote
D devindedog Honorable May 16, 2012 17 0 10,510 Sep 26, 2012 #3 I found some at Amazon. They are front panel cables. Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,566 321 107,640 Sep 26, 2012 #4 this from uk provider http://quietpc.co.uk/na-front-panel-ss or http://www.specialtech.co.uk/spshop/customer/Nanoxia-Front-Panel-Extension-300mm-Single-Sleeve--Black-pid-16646.html and this one http://www.ebay.co.uk/sch/i.html?_nkw=front+panel+extension+cable Upvote 0 Downvote
