Mobo Power question
Hello,
I am doing my first build and My Mobo is a Biostar TZ77B (http://www.biostar-usa.com/app/en-us/mb/introduction.php?S_ID=579). It has an ATXPWR2 connector which has 8 pins. My power supply (http://www.rosewill.com/products/1801/ProductDetail_Overview.htm) has a 4 pin ATX12V and an 8 pin EPS12V connector. I just want to verify that I can plug the 8 pin EPS12V into the 8 ATXPWR2 connector and not fry everything, or should I just plug in the 4 pin ATX12V? Thanks for any help.
2 answers Last reply
More about mobo power question
  1. Both will work and depending on what the cpu , ram video card and other components that you are putting you can get away with using the 4 pin. Some motherboards will come with an 8 pin connector and they will put a plactic cap over 4 of the pins so you only need the 4 pin connector. If there was no cap on yours then I would use the 8 pin especially if you have intentions of overclocking and/or having two video cards.
  2. Great. Thanks for the help!!!!
Power Motherboards
