Power Supply Brand/Model Check
  • Power Supplies
  • OCZ
  • Components
Last response: in Components
December 16, 2011 10:48:36 PM
Hey guys, I am looking for a 750w power supply (preferably modular but not absolutely necessary) and was wondering if this make/model was any good?
750W OCZ ZT Series ATX2.2 80PLUS Bronze Modular Power Supply
https://www.aria.co.uk/Products/Components/Power+Suppli...
If not are there any on that website that you would recommend?
Thanks a lot in advance,
More about : power supply brand model check
December 16, 2011 10:51:36 PM
In case you were wondering it is going to be powering an overclocked i5 2500k and in the future 2x560Ti in SLI.
December 17, 2011 8:42:24 PM
Okay thanks a lot for the advice but seeing as you said it is a solid unit I will probably get the OCZ ZT just for convenience of buying from the same store.
Again thanks a lot.
a b ) Power supply
December 18, 2011 2:38:34 AM
you'll be a happy customer with the zt
good luck
