AsRock Z77 Extreme4 standoffs too small? Please help!
I'm trying to insert my AsRock Z77 Extreme4 Motherboard onto the Antec 300 Case.
It seems the standoff holes on the motherboard is too small because the standoffs will not go through the hole.
Is this a problem? What do I need to do?
3 answers Last reply
More about asrock extreme4 standoffs small help
  1. I have the same case and I had no issue installing the standoffs.
  2. but do you have the same motherboard? the standoffs usually go through but this one just sits on top of the hole if you guys know what im saying.
    yes same mobo.
ASrock Motherboards
