System Voltage error - what will you lose if you take the battery out
  • Power Supplies
  • Battery
  • Keyboard Failure
  • Components
Last response: in Components
December 19, 2011 8:10:43 AM
Hi
I have a Dell which is showing a keyboard failure - battery voltage error on start up - I have had a look on your site and tried a the change plug idea and the push battery idea - nothing - now I would like change the battery..... problem is I cannot get the system data via F2 as the keyboard if not working :(  If I just take the battery out will I lose anything? Or can I get the system data another way - ie is it standard details?
Trace
More about : system voltage error lose battery
a b ) Power supply
December 19, 2011 9:49:52 AM
your system is telling you, you need to replace the bios battery.
so yes remove it but replace it with another, the error should go away and you should get your system back.
