Sign-in / Sign-up
Weird dispaly problem
  • Chipsets
  • Motherboards
  • Displays
October 1, 2012 8:45:59 AM
i made a video of my computer display problem please check it out
https://www.youtube.com/watch?v=cgxbzBU7blw&feature=you...
problem is when i on the system there is no display but when i press the shutdown button on cpu then display comes up showing system shutting down
no hardware error beeps during bios and windows os seems loading as graphic card fan usually runs in full speed during boot and when os is loaded it slows down synching with heat requirements
so what might be the problem?
thanks in advance
P.s i tried with a different gpu but still same problem
More about : weird dispaly problem
a b V Motherboard
October 4, 2012 2:07:14 AM
My guess is either a faulty PC power-on switch or (more likely) a faulty PSU.
m
l
October 4, 2012 4:40:10 AM
If its psu or any power related then it wouldn't be booting and windows wouldn't load..........any way culprit is found.....its the cable
m
l
October 4, 2012 4:47:26 AM
no dude
m
l
