Closed Solved
Will a double slotted card fit in my PC? [IMG attached]
Hey guys, this will be my first graphics card purchase, so I would like to get everything right! I humbly ask for your help.
Currently, I am eyeing the Saphire Radeon 5670 1GB GDDR5] (as per Tom's Hardware's Best Graphics Card for Money July 2011) and I noticed that it was double slotted. (one PCI-e slot, takes up two spaces) I looked at my computer, and there was a free panel, but there is a battery and some capacitoatrs also. Will the card fit?
Here is where I am planning on putting it:
http://img713.imageshack.us/img713/8269/photodco.jpg
Uploaded with ImageShack.us
The PCI-e slot is the long, black slot.
Here are the computer specificiations if it helps
If it can't fit, I am thinking of buying this one card albeit slower card.
Any other commentary is also greatly appreciated. Thanks again!
P.S: As a side note, will the default 300W power supply be fine for this card?
5 answers Last reply Best Answer
More about will double slotted card attached
  1. Best answer
    It'll be fine. The capacitor and battery will not interfere with any card.
    I prefer the following HIS HD 5670 to the Sapphire that you want. It's $5 more, but it exhausts the hot air directly out the back of the card rather than into your case.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161334
    However, to save money I would rather go with the following Sapphire HD 5670 512MB card for $63 after rebate. The HD 5670 is actually too slow to take advantage of 1GB of VRAM. You may get an extra 1 or 2 frames at best depending on your resolution by going with 1GB of VRAM.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102870
  2. as for your second question.....
    no there are really no gfx cards that will be supported by a 300 watt psu
    so
    with that being said..... if you have to invest in a new psu anyway....every 20 dollar bill more you put into that gfx card gets you a lot more
    Ah, very interesting. If that's the case, then the link that you posted seems to be the best bet. Why would they even sell a higher memory card if it cannot utilize all of the memory? Perhaps for overclockers? :S
    I apologize for doubting you BadTaylorX, but is there no way that the 300W power supply will function? The reason I ask is because the default PC came with an HD 4650 and apparently, this HD 5670 actually consumes less power!
    Thanks for the answers so far!
    EDIT: After looking a bit more, I have decided to go with your suggestion - the 512 MB Sapphire Radeon 5670 card. Thanks a billion!
  4. Best answer selected by Kanzu5665.
  5. This topic has been closed by Mousemonkey
Graphics Cards PCI Express Graphics Product
