Solved
Hardware in a remote connection
Hello,
If you run a remote desktop connection, can you control hardware connected to the host computer via the client computer?
For example, if I have a GPS connected to a host computer, can I control that GPS remotely by accessing the software on the host computer?
3 answers Last reply Best Answer
More about hardware remote connection
  1. Best answer
    little confused with the wording.
    if you are on PC1 and remotely connect to PC2 which has the GPS connected to it, then yes you should be able to control that hardware and software.
  2. Best answer selected by Teeeeeeeejas.
  3. Thank you very much.
    And sorry for the confusing wording. =)
vpn Hardware Remote Desktop Connection Computers GPS Networking
