Ok so when I was building my computer I didn't think about how many slots my computer really needed, in retro spec it really doesn't need more then it has now, but I find myself in a pickle because it doesn't.
First I have to ask is it even possible to put USB 3.0 in a computer with a motherboard that does not have it already? If the answer is no then well we kinda fixed that problem except I still do need a new USB card so that my computer recognizes my Madcatz SF4 TE stick.
Next is the wireless card, I don't yet know if this is worth it or not, my router is on the floor below and to the left of me and my signal is quite spastic. I was hoping maybe a wireless card vs a USB dongle would be better, but I'm running a G signal so it might not help at all.
The sound card is another thing I would like to add because my on board one does not have an optical port which wouldn't have been an issue till I started using my turtle beach headset on my PC.
So as you can see with only one PCI-E slot this seems to be impossible, but I figured I'd ask if theres some kind of work around I can employ.
For reference here is my mobo
http://www.asrock.com/mb/Intel/H61M-VS/?cat=Specifications
