I have built several AMD systems in the past, many using the stock cooler. This last build has me stumped. I put my Phenom II X4 980 processor in a new Gigabyte 990FXA-UD3 board and cannot get the stock cooler to latch. No matter which side I try to hook first, I cannot get the opposite side to extend low enough to hook under the nub. I have put way more downward pressure against the hooks than probably is wise. To no avail.
The processor is fully/properly seated in the socket (no bent pins), and its locking lever closes and locks easily, so I'm sure the processor isn't the issue. And, yes, I'm starting with the cooler's lever in the released position. The nubs on the bracket don't look any different than previous ones. Has anyone else had this experience? AMD didn't change something in the cooler bracket specs when they went to the AM3+ socket, did they? I know the bracket is two-piece now, but that shouldn't make any difference...
Btw, this is the first time I've tried to use the stock cooler that came with that processor. I've used my XIGMATEK LOKI cooler in the past. I wanted to try out the stock cooler and get some temp readings for comparison and check noise differences.
